June 22, 2018, 04:06:34 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Works in progress
| | | |-+  Super simple single screen for Mill or Router
Pages: 1   Go Down
Print
Author Topic: Super simple single screen for Mill or Router  (Read 4151 times)
Graham Waterworth
Administrator
Offline Offline
West Yorkshire, England
View Profile WWW
« on: July 16, 2017, 03:50:56 PM »
Here is a super simple screen for running a mill or router.  All the clutter is gone and its all you need to run a machine.
It was designed to use in education where all they need is to load some code and press go.
See what you think.
I will upload the files later when I have finished tweaking.
Graham
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
GRAYHIL
Active Member
Offline Offline
View Profile
« Reply #1 on: July 17, 2017, 03:12:14 AM »
Graham
Mach 3 or 4?
Will it support 4 axis?
Another Graham
Graham Waterworth
Administrator
Offline Offline
View Profile WWW
« Reply #2 on: July 17, 2017, 12:46:37 PM »
Hi Graham,
this one in Mach3 but we are working on a Mach4 one now, these are only 3 axis but later we will do a 4 axis set.
Graham
Graham Waterworth
Administrator
Offline Offline
View Profile WWW
« Reply #3 on: July 22, 2017, 07:01:03 PM »
Here we have the Mach4 version screen shot.
Tweakie.CNC
CNC is only limited by our imagination.
Global Moderator
Offline Offline
Super Kitty
View Profile WWW
« Reply #4 on: July 24, 2017, 12:20:05 AM »
Excellent work Graham.
I like simple  Smiley
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Steve303
Holding
Offline Offline
View Profile
« Reply #5 on: November 01, 2017, 10:43:30 AM »
Graham
Are the files available for the Super Simple Screen for Mach3? I am a super simple type guy that can use a super simple screen.  Grin
TOTALLYRC
Active Member
Offline Offline
View Profile
« Reply #6 on: December 06, 2017, 05:09:58 PM »
Very nice Mach 4 screen.
Mike
Tweakie.CNC
Global Moderator
Offline Offline
Super Kitty
View Profile WWW
« Reply #7 on: January 07, 2018, 06:40:33 AM »
Hi Graham,
Is the Super Simple Screen for Mach3 .zip file available for download please ?
Graham Waterworth
Administrator
Offline Offline
View Profile WWW
« Reply #8 on: March 20, 2018, 08:23:39 PM »
Tweakie, Mike,
It is now.
The screen set is provided as is, no changes will be made to it, it was done for use in schools where only the minimum amount of controls are needed and as such is great for just loading and running g-code.
With the windows menus turned off it makes it very hard to play with the settings and as such not much can go wrong. Or that is the theory, I am sure some kid will prove me wrong  Grin
* Mach3_SimpleScreen.zip (952.8 KB - downloaded 58 times.)
« Last Edit: April 15, 2018, 05:52:35 PM by Graham Waterworth » Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.20 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
