Hello Guest it is April 25, 2024, 08:16:40 PM
Author Topic: MAch3 Camera plugin V3  (Read 6495 times)
« on: July 10, 2017, 04:46:43 AM »
Hi
I added some new features to my camera plugin V3.
The settings for these feature have to be done in the Config Dialog.
1) a button "Move Offset" can optionally be set on the main window
2) "Set DRO to 0 at plugin termination".  If "Move Offset" is clicked and that checkbox is set, the plugin sets the X and Y DRO's to 0 when the plugin is terminated.
3) "Set DRO to 0 after offsetting". If "Move Offset" is clicked and that Checkbox is set, the plugin sets the X and Y DRO's to 0 when endposition is reached. This function is only available on machines controlled by the LPT interface, since tests have shown, that some motion controllers overwrite the DRO's.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: MAch3 Camera plugin V3
« Reply #1 on: July 10, 2017, 06:59:46 AM »
They will be great additions for sure.
I've downloaded the file and I'll update my machine when I'm next in the shop.
Thanks heaps.
Ozy.
« Reply #2 on: July 11, 2017, 05:56:04 PM »
Klaus,
Do you have plans to create a plugin for Mach4?  I've used your plugin on M3 and found it really useful for a laser system that I built.  I'm building a new system and contemplating using M4 but if there is no camera option then I'll probably stay with M3.
Thanks!
Brian
« Reply #3 on: July 12, 2017, 04:15:54 AM »
Hi Brian,
at the moment I don't plan to make a Mach4 cameraplugin. To be honest, I don't even know how a Mach4 plugin is look like.
Klaus
« Reply #4 on: July 19, 2017, 03:53:45 AM »
Hi
I released  a  new Version = V3.08
fixes and changes:
a user reported a jerky movement while jogging and the camera plugin activ, fixed.
checkbox "Terminate Plugin after Offsetting" added.
Klaus
