Hello Guest it is April 24, 2024, 08:51:03 AM
Author Topic: Axis movment indicator LED  (Read 2798 times)
« on: June 28, 2017, 03:23:18 PM »
Hi. I would like to make LED's on my panel to light up to indicate movment on each axis. So when my x-axis moves in positive direction I want 1 output to be activated, both if
axis are started by an G-code or by me hitting X+ jog button or using my jog wheel... Same for each axis and direction.
I really tryed to do this, but no luck so far.
Can some one help me with this one ?
SOR
Offline TPS
  •  2,505 2,505
Re: Axis movment indicator LED
« Reply #1 on: June 29, 2017, 03:28:25 PM »
you will Need a litle Piece of VB script in macropump to do this
i just write the code down, not tested or anything else, just to give you the idea.
If GetOEMDro(800) <> GetOEMDro(2500) Then //read an compare X DRO with stored Value
    Output ON // X axis is moving
else
    Output OFF // X axis is not moving
End If
SetOEMDro(2500) = GetOEMDro(800) //store X DRO for compare
Regards Thomas
« Reply #2 on: July 02, 2017, 07:55:12 AM »
Hi. Thank you for taking your time. But I just found out I didnt define what Mach version I use :) I use Mach4, so I guess I will need to do it
another way. If I am not wrong your solution  is for Mach3 right? I dont think Mach4 use VB.
SOR. ;)
Offline TPS
  •  2,505 2,505
« Reply #3 on: July 02, 2017, 10:47:28 AM »
my fault,
did not notice that it was posted under Mach4 General Discussion.
but i think something simular under LUA should work.
i have no idea from LUA.
Sorry.
