Hello Guest it is April 26, 2024, 04:10:14 AM
Author Topic: Incorrect Z-Axis zero/home position  (Read 8523 times)
Re: Incorrect Z-Axis zero/home position
« Reply #20 on: June 23, 2017, 09:06:27 AM »
RICH,
Once again, thanks for the great info.  Much of the concepts are familiar to me from research, and also my experiences with tweaking my 60 year old manual machines to work at their "best."
I love the idea of checking torque.  Can you tell me the type of indicator you use?  I only have torque wrenches for the motorcycles, which I use often and may be able to rig something up that can at least measure the differences in torque required - but likely not accurate measurements of the actual torque (any adapters will throw off proper calibrated measurement).  But I think the torque differences would be the telling measurement while reassembling the axis to recognize the misalignment etc.
This is a brand new build, and the parts I had cut before this Z issue developed were plenty accurate enough for my needs.  None of the parts we make for motorcycles are mission critical (you are not going to crash due to failure/tolerances of anything we make).  But getting the machine to be as accurate as possible - and more importantly repeatable, is something I am more than willing to spend the energy on.  It's time well spent.
You have made that job easier with your help and thorough explanations.
Attached is an example of a part cut on this machine.  The satisfaction of cutting it, and then mounting it perfectly to the bike is amazing! :)
Thanks again!
Scott
« Last Edit: June 23, 2017, 09:09:29 AM by motopreserve »
« Reply #21 on: June 25, 2017, 09:17:57 PM »
Made by TOHNICHI - model BTG120Z-S - 10-120 IN OZ.
Has 3 jaw chuck,easy to use and listed  for $550 some time ago.There are probable others,
but, I got it for cheap. You can use a torque wrench, beam type ( for ounces ), or small 1/4 drive
torque wrenches ( in pounds) for low torque values but they are not as sensitive as an actual measuring
gauge and everything should be calibrated.
A few of the tings things made for bikes in the past.
http://www.machsupport.com/forum/index.php/topic,6188.0.html
http://www.machsupport.com/forum/index.php/topic,6189.0.html
http://www.machsupport.com/forum/index.php/topic,6187.0.html
Have Fun,
« Reply #22 on: June 25, 2017, 09:30:03 PM »
That's some great looking work!  My clients lean a little less toward the grim reaper/skull & bones type of biker style, but I know good craftsmanship when I see it :)
Thanks for the info and links!
