Hello Guest it is April 23, 2024, 09:44:17 AM
Author Topic: Changing feed rate  (Read 1103 times)
Changing feed rate
« on: June 14, 2017, 05:01:36 AM »
Can someone advise if theyre having the same problem. When just running along a straight path (so y not changing) the feedrate varies quite signifiicantly? The feed you can see is changing all of a sudden from fast (1000mm) to slow (300mm) and then back up again  and the same when x isnt changing???
