Hello Guest it is April 20, 2024, 08:56:42 AM
Author Topic: Anyone have a Proma Compact 150 THC that actually works?  (Read 1148 times)
« on: June 10, 2017, 06:57:17 PM »
Got this THC with the table when I bought it and trying to get it programmed correctly. I've been cutting 12 ga sheet and the readout shows 88V when cutting without THC turned on. If I set the HYS on the THC to 88 or 90 with a 4V +/- range what should I set the HU to? The default is 200V. Also, under Config Ports & Pins in the Mill Options, does the "Allow THC UP/DOWN Control even if not in the THC mode" need to be checked?
Thanks, more to follow.
