Hello Guest it is March 28, 2024, 12:38:32 PM
Author Topic: Pokey 57u and PoNET kbd48CNC  (Read 3536 times)
« on: June 01, 2017, 11:59:15 AM »
There is ( Pokey 57u) and ( PoNET kbd48CNC )
I have a problem between the card and the control of about 80 cm.
I have trief to make the cable longer between them but it did not work at all ,and when I matched the original cable which is with the control,the problem stays the same with some more .Not all the actions work and it makes ( reset ) again and again.
 P.s.I have downloaded the latest version of the programs.
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokey 57u and PoNET kbd48CNC
« Reply #1 on: July 30, 2017, 04:57:22 AM »
The kbd48CNC MUST be connected to the PoKeys device with the cable originally provided. It should not be extended!
What are you referring to regarding that not all actions work? Mach3 or Mach4? In Mach3 you are free to remap signals on your own in the 'Mapping' section of the plugin settings. In Mach4, the keyboard uses the default set of actions and since not all are supported by Mach4, some actions may not work. However, you are free to use the 'Map to Mach4 signals' option and configure all buttons and LEDs on your own in Mach4 directly.
