Hello
Guest
it is
April 20, 2024, 02:30:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Z-Axis stuck in radius.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Z-Axis stuck in radius. (Read 2737 times)
aml9214
4
on:
May 18, 2017, 12:58:00 PM »
Just got my 6040 cnc. Naturally the controller was junk. Replaced the drivers and control card. Everything is up and running, still need to wire the vfd to the controller as well as the E-stop. My only issue at the moment is the z-axis is stuck in radius. Any help will be greatly appreciated.
Re: Z-Axis stuck in radius.
Reply #1 on:
May 19, 2017, 08:41:55 AM »
Mill or lathe?
aml9214
4
Reply #2 on:
May 19, 2017, 11:43:51 AM »
Mill
Reply #3 on:
May 19, 2017, 12:00:02 PM »
Stuck in radius relative to what?
aml9214
4
Reply #4 on:
May 19, 2017, 12:41:07 PM »
When I program to a positive 2.0 it goes to 1.0 away. When I'm milling a hole it cuts the hole to size but only goes half the depth I tell it. So if I program it .25 deep it only goes .125 deep. If I program it to Z0. It does go to 0.
rhtuttle
574
Reply #5 on:
May 19, 2017, 01:34:41 PM »
Does doubling your steps per unit solve the problem?
aml9214
4
Reply #6 on:
May 19, 2017, 01:50:15 PM »
We haven't tried that yet. Would ball screw pitch compensation have anything to do with it? If so does Mach3 have a pitch compensation setting?
http://www.linearmotiontips.com/common-ball-screw-terms-explained/
rcaffin
1,054
Reply #7 on:
May 20, 2017, 05:32:21 AM »
This has absolutely NOTHING to do with 'radius'. The concept is meaningless here.
You need to calibrate your Z axis. You probably need to HALVE the number of steps/mm.
Roger
Print
Pages:
1
Go Up
« previous
next »
