Hello Guest it is April 25, 2024, 03:08:45 PM
Author Topic: Step pulse  (Read 1645 times)
Step pulse
« on: May 13, 2017, 06:46:47 PM »
I want increase the step pulse to 60us. I tried to activate "Sherline mode" but the maximum step pulse is 40us. Could you give me the different step for increase the step pulse please.
Thank you
Re: Step pulse
« Reply #1 on: May 13, 2017, 07:27:07 PM »
I don't believe that you can.
Re: Step pulse
« Reply #2 on: May 16, 2017, 03:04:14 AM »
I think Ger is right, you cannot program Mach to produce a 60us pulse.
You could make a circuit to do so if you wish. It would require one IC timer per channel, probably a simple 555 timer for cents each.
Do you mind me asking why its necessary to have such a long pulse? Do you require similarly extended pulses on other channels/axes?
Re: Step pulse
« Reply #3 on: May 16, 2017, 02:58:28 PM »
It's work!! I have used NE555 timer. The datasheet of "CharlyRobot" said me that I have need a long pulse. I use a rack of CharlyRobot. I keep the power party and I have replaced the command party. Like this -> http://www.usinages.com/threads/un-nouveau-avec-une-charlyrobot-emc2-sous-linux.24645/
Thank you
Re: Step pulse
« Reply #4 on: May 16, 2017, 04:14:53 PM »
they look like ordinary steppers to me. I think I would try a regular stepper driver, probably a Geko and see if it works, I suspect it will.
Thereafter conversion to Mach is straightforward.
