Hello Guest it is April 19, 2024, 07:10:58 PM
Author Topic: Using the Parallel Port with Mach3.  (Read 9560 times)
  •  9,198 9,198
« on: May 10, 2017, 07:56:08 AM »
Most computers nowadays are no longer provided with the old Cannon D type, 25 way, parallel port connector. Although this limitation can be overcome by installing a suitable PCI parallel port card there is a catch…
The old, original 5 Volt TTL standard (used in the days of parallel port printers) has to a large extent now been replaced with a new 3.3 Volt TTL standard. Many of our existing breakout boards and drivers etc. were designed for 5 Volts TTL operation and  these older devices may not operate correctly with 3.3 Volt TTL.
When buying a new PCI parallel port card, unless you are confident that your existing equipment will work with 3.3 Volt TTL, then, to be on the safe side, always get a PCI card which provides 5 Volt TTL outputs.
How do you tell the difference ?
Please refer to the following diagram (thanks to Phame)…
Firstly, ensure that your PC motherboard does in fact have a 5 Volt PCI slot.
Next choose a PCI card which has the correct cut-out position for the 5 Volt PCI slot.
This may not be a totally fool-proof method of choosing the correct 5 Volt PCI card but it at least lets us identify the 3.3 Volt cards.
One final note – the parallel port can only be used with operating systems up to (and including) Windows 7 and it cannot be used with any 64 bit operating systems.
« Last Edit: May 10, 2017, 08:30:06 AM by Tweakie.CNC »
Re: Using the Parallel Port with Mach3.
« Reply #1 on: May 11, 2017, 08:38:40 AM »
I have had good success using the following PP cards with Windows XP.
Rosewill RC-302 - Low-Profile PCI Card - Single Parallel (SPP / PS2 / EPP / ECP) Universal
                  5V PCI slot only
                  approx $14.00
Rosewill RC-304 - 2-Port Parallel (SPP / PS2 / EPP / ECP) Universal PCI Card
                  5V PCI slot only
                  approx $22.00
I prefer the 2 port card.You can find them on Ebay and other places. Some other makes were not to my liking.
