Hello Guest it is April 24, 2024, 11:01:05 AM
Author Topic: mach3 license  (Read 1864 times)
mach3 license
« on: May 09, 2017, 11:23:27 PM »
Hello,
I bought a license like 6 or 7 years ago. My computer just died so I have a new one. Can I reload the software again or do I need to purchase the license again.
Thank you
Re: mach3 license
« Reply #1 on: May 09, 2017, 11:36:54 PM »
Hi
If you do not have the original license file  sent to you when you purchased it, contact the seller as they may have it on file. Otherwise contact Mach3 support as they should be able to sort you out.
Once you have the license file, place it into the Mach3 directory. This is usually C:\mach3
To get the Mach3 software download it from the Mach support site.
Peter
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
Re: mach3 license
« Reply #2 on: May 10, 2017, 12:20:48 AM »
thank you I found my email with the original license. I put it on my desktop and dragged into the mach 3 folder but the dat file won't seem to open and run. ant particular program I should use to get the dat file to open and run. still showing demo in mach 3?
Offline RonC
  •  32 32
Re: mach3 license
« Reply #3 on: May 26, 2017, 04:10:40 AM »
I Don't know if you have sorted this by now, but you just need to put the .dat file in your Mach 3 folder, Mach will find it next time it runs and all should be good.
