Hello Guest it is April 26, 2024, 05:52:37 AM
Author Topic: File operations, reading a line of position data  (Read 3804 times)
Re: File operations, reading a line of position data
« Reply #10 on: May 09, 2017, 03:04:29 AM »
Reinhard, Thanks for the warning!  Don't worry, I am using the Api for ini and reg file access.  Only using direct file io for .txt and .csv files.
Keith
« Reply #11 on: May 09, 2017, 07:56:28 PM »
I reused a piece of LUA code I found in one of the LUA Examples folder that ships with Mach4.
It is a file navigation panel which allow you to browse for a file and open it. Its structure and
operation owe more to wxWigets than LUA or Mach4....
Code: [Select]
inst = mc.mcGetInstance();
    -- create the wxFrame window
    mainframe = wx.wxFrame( wx.NULL,          -- no parent
                        wx.wxID_ANY,          -- whatever for wxWindow ID
                        "DummyFrame", -- frame caption
                        wx.wxDefaultPosition, -- place the frame in default position
                        wx.wxDefaultSize,     -- default frame size
                        wx.wxDEFAULT_FRAME_STYLE ); -- use default frame styles
    -- create a panel in the frame
    panel = wx.wxPanel(mainframe, wx.wxID_ANY);--We are not going to show it but we need to have this to use the File dialog
local file = wx.wxFileDialog(panel, "Select Probe File", "", "", "Text files (*.txt)|*.txt|Tap files (*.tap)|*.tap",
                             wx.wxFD_SAVE,wx.wxDefaultPosition,wx.wxDefaultSize, "File Dialog" );
        if(file:ShowModal() == wx.wxID_OK)then;
            local pathRPF = file:GetPath();
-- Edit this format statement at your own risk
mc.mcCntlProbeFileOpen(inst, pathRPF, "X%.4AXIS_X Y%.4AXIS_Y Z%.4AXIS_Z\r\n", true);
Maybe of use.
« Reply #12 on: May 10, 2017, 05:22:27 AM »
Thanks Craig, I have done the same thing.  It is very helpful.   Thatt and stealing the wx.messagebox is about the exrent of my widgets prowess!
« Reply #13 on: May 10, 2017, 07:28:09 AM »
I have written a macro that reads a Gcode file line by line, makes a  correction to each line, adds the corrected line
to a new file until the end of the input file.
To get the file uses a file navigation panel as above and uses the following to open:
Code: [Select]
local file = wx.wxFileDialog(panel, "Select G code File", "", "", "All files (*.*)|*.*",
    local pathCode;
        pathCode = file:GetPath();
    end;
I use this line to open the file:
Code: [Select]
local hin=assert(io.open(pathCode,"r"));
And these lines to read line by line until the end of the file:
Code: [Select]
while true do;
        inline=hin:read("*L");
        if inline==nil then break end;
The body of the loop has LUA string statements necessary to effect the correction I need made.
The description of the string manipulation tools can be found at:
https://www.lua.org/pil/contents.html
While the string functions seem a bit simplistic they can be combined to offer nearly all the ANSI string functions. They could very handily
be used to extract data points from a comma separated file for instance.
In fact this link is my primary resource for LUA coding help. Doesn't have any Mach API stuff or any wxWidgets but everything else LUA.
« Reply #14 on: May 10, 2017, 08:29:22 AM »
Fantastic!  Thanks so much. I will study.  I am sure others will be helped as well.
Offline mzc
  •  11 11
« Reply #15 on: September 17, 2022, 06:20:23 AM »
Thanks Craig, this was just the info I needed for my mach4 GUI.
