Hello Guest it is April 19, 2024, 01:26:48 AM
Author Topic: Backlash copensation issues  (Read 6617 times)
Offline Mauri
  •  328 328
Re: Backlash copensation issues
« Reply #10 on: May 22, 2017, 10:04:49 PM »
Sparky3i,
I am now back to cutting the medallion.
This cut in to finish what stopped 2 weeks ago.
its a 7+ hour cut and it still cutting past the 4 hour mark.
I am using v63 on this cut with V3383.
We only have Steppers with no feedback so you differ with your servos.
I have tried to use steps of .0025mm (2 Pulses exact) = .0001" and it seems to be OK, but reverted back to .01mm (8 Pulses exact) good enough for our hobby mill.
You might want to manually calculate the pulses, do you get an even number Steps Per X your Step Distance.
Thanks to Rufi hard work all is looking good, I will be testing V3390 as he has posted the Plugins.
Mauri.
