Hello Guest it is April 20, 2024, 06:50:36 AM
Author Topic: Need help urgently.  (Read 1995 times)
Need help urgently.
« on: May 04, 2017, 09:12:47 PM »
Hello, new here...
My main Mach 3 Computer Died, so i had to make a new Computer.
It is running Windows 7 home 32bit
dose not have a on board parallel port on board so I installed This one ( https://www.amazon.ca/gp/product/B001Q7X0Z8/ )
Here is my I/O Range, and ports and pins page.
http://i.imgur.com/mmhVIqY.png
I am unable to control my cnc, and I am all out of Ideas on how to fix this... Anyone see any glaring problems?
Thank you
Re: Need help urgently.
« Reply #1 on: May 05, 2017, 02:29:14 AM »
The 1284 PCie Parallel Card PEX1P is 3.3v
  •  9,198 9,198
« Reply #2 on: May 05, 2017, 03:41:07 AM »
The 3.3 volt parallel port output could be the problem if your BoB / Driver is expecting a 5 volt TTL signal.
What make and model breakout board / driver are you using ?
« Reply #3 on: May 06, 2017, 06:43:42 PM »
if you open Device Manager I would expect to see Machs parallel port as a physical device.. something like 'Mach Pulse Engine' or similar.
It is one of the indications that Machs PP is NOT in fact a parallel printer port but is in fact tied to some very tricky low level software competing
with or at least in co-operation with Windows Kernel.
  •  9,198 9,198
« Reply #5 on: May 10, 2017, 01:16:45 AM »
Here is a pic showing how to tell if it is 3 or 5 volts.
Thanks for the information Phame.
