Hello Guest it is April 24, 2024, 03:22:08 PM
Author Topic: Cutter height advancement problem  (Read 3212 times)
Offline Stuart
  •  311 311
Re: Cutter height advancement problem
« Reply #10 on: May 08, 2017, 11:40:50 AM »
Set your max tools in the mach4 config I have mine at 200
« Reply #11 on: May 08, 2017, 02:37:44 PM »
You might be better off learning about G50 and work offset shifts
Increment the whole work offset Z #variable position.
Screw around with tool length offsets is subject to a whole new set of "what the hell happened there"
You might beable to write to the tool length variable then call it with an H offset but resetting it and knowing where your at any one time is going to be suspect too.
Being new to this  I advise to learn the basic before you crash, burn then  :'(
« Reply #12 on: May 08, 2017, 04:22:26 PM »
Ya-Nvr-No
I have it running quite well with your earlier suggestion of offsetting each and every call for Z. It only takes a couple strokes of copy/replace.
"You might be better off learning about G50 and work offset shifts
Increment the whole work offset Z #variable position."
I should look into how that offset can be adjusted per pass with a var..
