Hello Guest it is April 26, 2024, 02:32:35 AM
Author Topic: MACH 3 CSMIO axis starting on reset  (Read 1347 times)
« on: May 02, 2017, 05:37:09 PM »
Hi
wonder if anyone can help, im new to this product and hardware. I have installed a CSMIO controller/encoders from cs labs with MACH 3. My issue is that I have configured the soft/hardware to the manufacturers recommendations, all seemed to be well then the Y axis randomly starting to accelerate to either + or - without command, I tried altering various settings without any luck. I decided to reinstall MACH as i thought i may have entered an incorrect setting, matters became worse, all the axis when the MACH button is reset accelerate quickly causing an epid error. Once again tried all settings without success including motor tuning etc. Is there any setting in mach 3 general config or otherwise that could cause this issue that i am overlooking,
Any help would be appreciated
Re: MACH 3 CSMIO axis starting on reset
« Reply #1 on: June 22, 2017, 08:18:05 PM »
Hello.  Have you resolved this issue?  Which CSMIO controller are you using? IP-A?  I have similar problems and am using the IP-A.  About to contact CSLabs to see if they know.  Thanks
