Hello Guest it is April 24, 2024, 04:13:41 AM
Author Topic: Should (Can) I buy Mach 3  (Read 11126 times)
  •  9,199 9,199
Re: Should (Can) I buy Mach 3
« Reply #20 on: August 07, 2017, 02:44:11 AM »
Yes you can run Mach3 under Windows10 (without installing the parallel port drivers).
Mach3 does not actually generate Gcode it just runs it.
CAM or CAD/CAM software is used to generate Gcode.
Yes you could transfer Gcode from one computer to another using a thumb drive.
No, it would be absolutely nothing like an external motion controller. :)
Hope this helps.
