Hello
Guest
it is
April 19, 2024, 09:14:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Reverse Run
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Reverse Run (Read 1696 times)
rrc1962
673
Reverse Run
on:
April 25, 2017, 01:20:24 PM »
Has reverse run been impemented in M4? I don't see a function in the documentation or button action for it.
Logged
rrc1962
673
Re: Reverse Run
Reply #1 on:
May 14, 2017, 12:26:46 PM »
Anyone have any ideas on this one? I see an output for reverse run, but no button action or function to activate it. Do you just turn the output on and off to activate/deactivate?
Logged
rrc1962
673
Re: Reverse Run
Reply #2 on:
May 15, 2017, 07:25:00 PM »
Anyone? The manual talks about reverse run and shows images of a reverse run button, but none of the stock screensets have it.
Logged
Kolbot
4
Re: Reverse Run
Reply #3 on:
May 24, 2017, 02:52:49 AM »
Do you mean reverse like the option you can tick in the motor configuration? (Mach-configuration -> Motor -> Little reverse tick on/off box)
Logged
rrc1962
673
Re: Reverse Run
Reply #4 on:
May 24, 2017, 08:39:10 AM »
No, reverse run like why was available;able in M3. When activated, it runs the tool path in reverse. Anyway, tech support says this feature is not available in M4.
Logged
Print
Pages:
1
Go Up
« previous
next »
