Hello Guest it is April 18, 2024, 10:57:55 PM
Author Topic: STEPGEN = 0  (Read 6312 times)
STEPGEN = 0
« on: April 16, 2017, 05:37:23 PM »
im currently in the process of converting my CNC over from a USB smooth stepper to the Integra, as well as from mach 3 to 4.
i have everything wired up properly  ;) but none of the motors will budge. when i attempt to jog them in mach 4 the DRO's just sit at 0.
under Diagnostics-> Hicon i can see the Cammand Pos and Following Error move with the jog buttons, but StepGen and the DRO's sit at 0.
sounds like a missed a checkbox somewhere.
i tried to download the integra mach4 profile off the website, but the folder doesnt contain any *.m4prof files =[
any ideas?
Re: STEPGEN = 0
« Reply #1 on: April 16, 2017, 06:45:43 PM »
to make sure im not crazy, i went back to mach 3 and the old USB smooth stepper and everything jogs back and forth and the DRO's move accordingly.  :)
Re: STEPGEN = 0
« Reply #2 on: April 17, 2017, 03:10:49 PM »
We have updated the website and now the sample profile is in .m4prof format. It is available in the download area:
www.vsys.co/integra#downloads
After you download the file run Mach4 (C:\Mach4-Hobby\Mach4GUI.exe) and click Import Profile and browse to the downloaded file (Mill3Axis-Integra.m4prof).
Ricardo T.
Re: STEPGEN = 0
« Reply #3 on: April 17, 2017, 06:31:28 PM »
Ricardo,
thanks for the super fast response!
profile the .m4prof imported fine, i can tell the inputs/outputs have changed. Control input and output came as MACHxx and Stepper.  but i still have the same problem. Cammand Pos and Following Error move with the jog buttons, but StepGen the DRO's and the motors sit at 0 =[
-Mike
Re: STEPGEN = 0
« Reply #4 on: April 18, 2017, 02:32:19 PM »
Try rebooting your PC and cycle power to the controller. If that doesn't solve the issue we can remote login using Team Viewer and do some troubleshooting.
Re: STEPGEN = 0
« Reply #5 on: April 22, 2017, 02:12:18 PM »
unfortunately rebooting everything didnt help.
but i have a suspicion it might be e-stop related. the command prompt that runs in the background of mach 3 keeps posting "mach external still set". which isnt super descriptive but it does seem significant. see attached image.
Re: STEPGEN = 0
« Reply #6 on: April 22, 2017, 06:33:58 PM »
what times are you guys available to remote login? (eastern std time)  im guessing you work the same hours i do?
Re: STEPGEN = 0
« Reply #7 on: April 22, 2017, 08:33:36 PM »
Are you using Mach3 or Mach4?
Do you see Integra in the vsiDeviceManager network scan?
you can call the office at 9:30am AZ time weekdays and we can do a remote login.
If you are using Mach4, email a screen capture of diagnostic > vital > hicon status window to the support email address.
regards
Rufi
Re: STEPGEN = 0
« Reply #8 on: April 23, 2017, 08:59:11 AM »
ok so, problem solved  ;D. operator error is to blame for this one, well that and not having a proper understanding of what the software was looking for...
i had bought the 7737 expansion with the integra and never plugged it in because i hadn't bought the license for closed loop yet... however, it was enabled inside of the VSI device manager. once i found that setting i left it enabled, plugged in the 7737, and still nothing... imported a fresh copy of the Integra mach 4 profile and BAM!!!! off and running! the funny thing is the motors are still wired into the integra, the 7737 is just dangling by the ribbon cable with 24+ and the e-stop jumped out.
but who cares!!!! she runs!!!
now i just need to find that spool of ethernet wire and try running through the 7737, but i have a feeling it'll work just fine.
ok so, Vital Systems, thank you for your wonderful product, your assistance in this matter, and my apologies for the stupid on my part!
Re: STEPGEN = 0
« Reply #9 on: April 23, 2017, 09:11:38 AM »
Hi Overcooked,
Nice to see someone admit that they didn't know everything.
They guys from Vital are great to work with which is why I have been a happy user all these years.
