Hello Guest it is April 19, 2024, 12:42:49 PM
Author Topic: Change buttons in active work offset  (Read 2814 times)
« on: April 14, 2017, 07:14:01 AM »
Hi There,
I use the working offsets quite a lot. Fixture 1 (G54) and so on. I keep forgetting which fixture to use for different jobs. It would help me a lot if i could change the names in the button for example to Vacuumtable, centre, flipside mould etc. No problem if i have to change the tekst in photoshop or whatever, but i cannot find the location where these buttons are located.
Any help will be appreciated
Kind regards
Fred
Re: Change buttons in active work offset
« Reply #1 on: April 14, 2017, 07:32:52 AM »
You may want consider creating some buttons such that you can select, alter, save the offsets.
Attached pic show what was added  for my lathe screen. You will need to use a screen editor like Machscreen to do.
« Reply #2 on: April 14, 2017, 11:37:16 AM »
Fantastic thanx, found it, and found out how to work it. This makes my life a bit easier ;)
