Hello Guest it is April 26, 2024, 07:57:15 PM
Author Topic: Reading text box on screen  (Read 4836 times)
Offline gorf23
  •  189 189
Re: Reading text box on screen
« Reply #10 on: April 11, 2017, 06:44:45 PM »
As far as I know I know they changed the license's with one of the updates but you can get a new one if that is the case...
« Reply #11 on: April 11, 2017, 07:11:00 PM »
I'm on 2914.  Can I update without upsetting the license, screenset or directories I'm currently working on?  I know Mach 4 uses a different licensing scheme than Mach 3
Other than the license, absolutely ........assuming of course you have not been modifying anything that comes with Mach (defaults, which no one should ever modify). Customizing defaults makes a mess and is almost always a very bad idea.
License changed at some point but you can login to your account you created when you bought the license and mange your license if you need to disable the existing and generate a new one.
« Reply #12 on: April 11, 2017, 07:20:39 PM »
That was it.  The textbox now has a "Value" property.  As far as I can tell, the license is still good.  How can you tell if you're in demo mode?  I'm not running a machine, just developing.
« Reply #13 on: April 11, 2017, 07:40:21 PM »
Licence is still good.  Another install I have that is not licenced says Demo at the top.  Also says Unlicenced on the about screen.
Offline gorf23
  •  189 189
« Reply #14 on: April 11, 2017, 07:56:21 PM »
contact support and ask for a new license
