Hello Guest it is April 26, 2024, 04:53:16 PM
Author Topic: New Feed Hold button  (Read 2170 times)
Offline CNCDK
  •  23 23
« on: April 08, 2017, 11:49:55 AM »
How I made so I can use an input to "Feed Hold" ??
I have input available on my bob (P13)
Offline olf20
  •  325 325
Re: New Feed Hold button
« Reply #1 on: April 09, 2017, 08:03:48 AM »
Goto config - inputs
Scroll down to oem#1
Assign correct port / pin
Then goto config - system hotkeys
Assign feedhold number from Hoods list above.
The number is in the 1000's
Save
Run
olf20 / Bob
« Last Edit: April 09, 2017, 08:10:48 AM by olf20 »
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Offline CNCDK
  •  23 23
« Reply #2 on: April 15, 2017, 05:02:30 PM »
Hi
can you describe in a better way how I do after this ??
Save
Run
Offline olf20
  •  325 325
« Reply #3 on: April 15, 2017, 07:35:27 PM »
If you look at page 8 of Hoods OEM CODE List.
Open it with a spreadsheet program.
Scroll down to the 1000's and you
will see 1001 is PAUSE or feedhold.
This is the number you enter for the OEM Code #1
on the right hand side under System Hot Keys.
Of course you have to assign your port and pin
number to INPUT #1, under Configure, Ports & Pins,
Inputs.
Hope this helps. It is a little confusing and I may have
not explained it the right way.
Post back if you get hung up.
olf20 / Bob
« Last Edit: April 15, 2017, 07:38:04 PM by olf20 »
Offline CNCDK
  •  23 23
« Reply #4 on: May 09, 2017, 06:37:09 PM »
1000 thanks
