Hello Guest it is November 13, 2026, 09:06:03 AM
Author Topic: Lua script command  (Read 8464 times)
Offline Julie
  •  18 18
Lua script command
« on: April 07, 2017, 07:44:01 AM »
Hello,
I'm converting VB script to LUA script.
<VB script>
Call SetOEMDro(802, ZeroOffsetZ)
How can I change that by Lua script command?
Offline Julie
  •  18 18
Re: Lua script command
« Reply #1 on: April 10, 2017, 12:27:28 AM »
I solved it. :)
« Reply #2 on: April 10, 2017, 12:53:48 PM »
Hyojung,
You should put your solution on this thread so others can see what works.
Chad Byrd
Offline gorf23
  •  190 190
« Reply #3 on: April 10, 2017, 01:47:23 PM »
If you want to call a global function that has been put into the screen load script, is there a special way to call it from a script
I put a WriteRegister function in the load screen script  but if I try to call it from a button script I always get the error
attempt to call global 'WriteRegister' (a nil value)...
Is there a special way to call functions that are in the screen load script or do I need to add it somewhere else also
it will run fine if I have the function in the button script and run debug...
Offline Julie
  •  18 18
« Reply #4 on: April 19, 2017, 06:37:07 AM »
Cbyrdtopper, sorry.
I changed it as shown below.
mc.mcAxisSetPos(inst, 2, ZeroOffsetZ)
But I thought I solved it, but I do not know if it is correct.
« Last Edit: April 19, 2017, 06:43:50 AM by Hyojung »
