Hello Guest it is April 16, 2024, 05:46:46 AM
Author Topic: Cnc plasma thc  (Read 1459 times)
Cnc plasma thc
« on: April 03, 2017, 06:01:03 PM »
Anyone have proma thc with his hypertherm machine ?  i have powermax 85 and I use the cpc port signal (50/1) to go to thc. When i start cutting , My torch goes too high , about 1/2 inch from the material . The material is 3/16 mild steel , so I set my speed to 75 ipm, thc at 135v, 45 amps ( hypertherm speed chart). I read 3.2v from cpc port ..  I set the hysteresis at 4 on proma .  Thanks in advance
Offline Davek0974
  •  2,606 2,606
Re: Cnc plasma thc
« Reply #1 on: April 04, 2017, 02:12:42 AM »
Where do you get your 135v from??
If it is from "the book" forget it - do some straight line cut tests with z up/down turned off and note the voltage which gives you the correct height, this is then your voltage for that material at that speed and at that current.
