Hello Guest it is April 25, 2024, 07:18:53 PM
Author Topic: lua script require() question  (Read 1746 times)
Offline gorf23
  •  189 189
« on: April 03, 2017, 03:54:58 PM »
is there a way to use require() in a lua script without having a file dialog box loaded,  or is that another lua command to do the same call without a file dialog box.
It seems to works for calling a lua script from another lua script and being able to pass variables just don't want to wait to pick the file...
thanks
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: lua script require() question
« Reply #1 on: April 03, 2017, 04:55:09 PM »
The require function is to load modules, take a look in the Screen Load Script and see how its being used there.
DazTheGas
Offline gorf23
  •  189 189
« Reply #2 on: April 04, 2017, 04:51:26 PM »
Thanks daz
I used some code form the load screen script it works, it will load my module and run it... But it always pop's up a file dialog box i have to pick the file and click ok
I just want the module to load and run with no file box...
Offline smurph
  •  1,546 1,546
« Reply #3 on: April 20, 2017, 04:41:28 PM »
This is a path issue.  If lua can't "find" your module, it will ask you where it is via the file dialog.  Make sure the module's path is in the package.path.
Steve
