Very confused about use of wx versus Lua programming. I have looked at the links for Lua docs and the references for widgets - very complicated! I would like to use widgets but even the example below is confusing.
How do I edit the code below to make it function. I just want to be able to input a file name from keyboard. Is there an easier way to collect keyboard text in Lua?
function M401()
inst = mc.mcGetInstance();
-- create the wxFrame window
mainframe = wx.wxFrame( wx.NULL, -- no parent
wx.wxID_ANY, -- whatever for wxWindow ID
"DummyFrame", -- frame caption
wx.wxDefaultPosition, -- place the frame in default position
wx.wxDefaultSize, -- default frame size
wx.wxDEFAULT_FRAME_STYLE ) -- use default frame styles
-- create a panel in the frame
panel = wx.wxPanel(mainframe, wx.wxID_ANY)--We are not going to show it but we need to have this to use the File dialog
local file = wx.wxFileDialog(panel, "Select Probe File", "", "", "Text files (*.txt)|*.txt|Tap files (*.tap)|*.tap",
wx.wxFD_SAVE,wx.wxDefaultPosition,wx.wxDefaultSize, "File Dialog" );
if(file:ShowModal() == wx.wxID_OK)then
local path = file:GetPath()
--wx.wxMessageBox(tostring(path))
Set the output of the probe points with the format String
Example:
X%.3AXIS_X
will output X<xprobevalue>
mc.mcCntlProbeFileOpen(inst, path, "X%.3AXIS_X Y%.3AXIS_Y Z%.3AXIS_Z A%.3AXIS_A\r\n", true);
end
end
M401()
end
