Hello Guest it is April 18, 2024, 11:54:57 AM
Author Topic: Help writing G-Code  (Read 9815 times)
Re: Help writing G-Code
« Reply #10 on: June 19, 2007, 03:57:33 PM »
well according to the sound logic breakout board I am using they say to use mach 2. I tried to use mach 3 and I couldn't get it to work but I didn't try too hard because the instructions said to use mach 2
« Reply #11 on: June 19, 2007, 05:45:16 PM »
I really couldn't tell you one way or the other.
I would suggest click tutorials>Documetation above, then download using Mach2 and customizing mach2  somewhere in the pdf it should have the info on increasing stepper speed.
Wes
Have a nice Day
« Reply #12 on: June 19, 2007, 07:47:28 PM »
smr14,
   I have sent you a personal message. A G0 move is a rapid. A G1 is a feed. You can change the rate in the code listed below by placing a f********* in the line of code. This will not increase the rapid speed or override it. The fastest it will move is the amount you have set in motor tuning. I would go with Mach3 as well.
