Hello
Guest
it is
April 25, 2024, 04:23:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Promote and discuss your product
New BRC series 150V 20A Servo Drive from Machdrives
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: New BRC series 150V 20A Servo Drive from Machdrives (Read 6998 times)
machdrives
5
on:
March 21, 2017, 08:19:39 PM »
machdrives.com
announces the release of the new BRC series servo drive. This is our third new servo drive model for 2017, and is a low cost open frame design.
Rated at
20-150VDC
input and
20A
output, it is ideal for CNC mills, routers, lathes and plasma cutters. List price is AUD $199
Download BRC User Manual
While there are several other similar offerings in the market, the Machdrives BRC servo has some important differentiating features..
Lower heat generation.
The combination of a switching regulator, power saving mode and an efficient MOSFET bridge means the drive can be screwed directly to the control cabinet wall in many applications, without requiring an additional heatsink.
More accurate tracking.
Extending the traditional PID control with velocity feedforward, acceleration feedforward and stiction compensation eliminates tracking errors normally present on starting and acceleration.
Easier setup and tuning.
Connection with a standard USB cable to the free Tuna for Windows application means easy setup without an oscilloscope. The 14 LED indicators show all signal and I/O pin status to streamline commissioning and troubleshooting.
20-150VDC 20A brushed DC servo drive.
Step/Dir input compatible with Mach3.
Low cost open frame design.
High efficiency. Minimal heatsinking required.
14 LED indicators for easy setup and diagnostics.
Configure with standard mini-B USB cable.
Easy tuning with free Tuna™ software for Windows.
Latest control algorithms. Dual 32bit ARM CPUs.
Smooth silent operation. No dithering.
Voltage, current and temperature alarms.
High noise immunity with isolated control circuitry.
Designed and manufactured in Australia.
Print
Pages:
1
Go Up
« previous
next »
