Hello Guest it is April 25, 2024, 12:06:08 AM
Author Topic: USB to 25 pin break out board  (Read 1561 times)
« on: March 20, 2017, 11:39:30 AM »
The PC has a USB port.
The machine controller has a 25 pin break-out board  (C10).
Is it possible to run mach3 using a simple USB to 25pin lp1 cable?
I'm guessing there is more to it.
Offline kolias
  •  1,154 1,154
Re: USB to 25 pin break out board
« Reply #1 on: March 20, 2017, 11:55:09 AM »
The C10 needs a printer parallel port to connect to PC with a good parallel printer cable which means all pins on that cable should be through from one end to the other. You can get an old PC with a printer cable port for about $20-35 and the older the PC the better. But you can also add a printer port card to your PC.
Nicolas
« Reply #2 on: March 20, 2017, 12:52:43 PM »
Thank you for the info.
