Hello
Guest
it is
March 28, 2024, 06:38:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
MACH4 restartimg in the middle of post
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MACH4 restartimg in the middle of post (Read 1248 times)
Maginsky
11
on:
March 16, 2017, 10:05:47 AM »
I was in the middle of machining a small part on my CNC milll using MACH 4. Assuming everything is still set...can the sequence be started from where it left off? Or should I start from the beginning and let it machine air till it catches up?
nick952
42
Re: MACH4 restartimg in the middle of post
Reply #1 on:
March 18, 2017, 10:02:59 AM »
Hi Maginsky,
Check out page 42 of the Mach4 Operation Manual:-
http://www.machsupport.com/wp-content/uploads/2014/05/Mach4%20Operation%20Manual.pdf
Just play around with the method outlined in the above (on a trial part, at slow feed and with your hand over the E-Stop button). Also use the FEED HOLD button and check the DISTANCE TO GO VALUES on each axis, untill you are comfortable with it.
Nick.
Last Edit: March 18, 2017, 10:08:21 AM by nick952
Print
Pages:
1
Go Up
« previous
next »
