Hello Guest it is April 26, 2024, 12:00:10 PM
Author Topic: Script When loading a screen set  (Read 3247 times)
« on: March 15, 2017, 08:49:07 PM »
One day I was browsing for Mach information and I found a link (which I should have saved) that said there is a location or script or something that you can add or modify so that when your screen set loads you can script certain things...
I need to set certain OEMDRO's & OEMLED's, select a specific page etc...
All of those things I know how to do but I dont know how to automate it when the screen set loads
Can some one help? Point me in the right direction?
Thanks in advance
Velox 4 Axis Router, Mach3, Windows 7 32 bit
Modified to also be a Plasma / Engraver
with a Dual Chamber Water Table
Some of my work
https://mygarageshop.com/
ScreenSet: SmartScreens for Mach3
https://ngeneyes.com/smartscreen/licensing/
  •  9,200 9,200
Re: Script When loading a screen set
« Reply #1 on: March 16, 2017, 03:37:47 AM »
If you put what you want to do into a macro then that can be called at startup by adding it to the Initialization String (Config. / General Config.  -  Startup Modals).
