Hello Guest it is April 18, 2024, 11:39:18 PM
Author Topic: help needed with atc macro for mill retrofit  (Read 11680 times)
Re: help needed with atc macro for mill retrofit
« Reply #10 on: March 17, 2017, 12:50:22 PM »
for the moment i am little bit confused about the ligic of input1 for doing one step of ATC
in the original macro:
--> UNTIL IN4 OR STOPSW
--> REPEAT
--> UNTIL !IN4 OR STOPSW
--> REPEAT
--> REPEAT
it looks like it is ON at the start
then OFF ON OFF ON
to do one step at ATC
please describe the pattern of input1 to do one step.
Thomas
Hello, that correct it will start ON
then OFF ON OFF ON (ending in ON)
this would equal 1 tool position so if i was at tool 1 and ran that id end up at tool 2 if i was at 1 and ran it in ccw it would be tool 8.
Offline TPS
  •  2,505 2,505
« Reply #11 on: March 17, 2017, 03:22:18 PM »
ok then something like this should be closer:
Code: [Select]
Sub Main()
'Global variables declaration
Dim CCWPos as Integer
Dim CWPos as Integer
NewTool = GetSelectedTool()
OldTool = GetCurrentTool()
While NewTool > 8
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
If NewTool = OldTool Then'Compare between actual tool and requested tool
   Else
   End If
If NewTool > 8 Then'requested tool higher then tool numbers
   Else
   End If
If NewTool < 1 Then'tool number to low
   Else
   End If
code("m05")
   Call ZatcPosition
   Call AtcIn'Activate air cylinder valve to put old tool back to carrousel
   Call Unclamp'Spindle: Tool Unclamp
   Call AtcDown'lowers atc
   Call LeastTravel'determine the least travel to move and Turns CW or CCW
   Call AtcUp'raises atc
   Call Clamp'Spindle: Tool Clamp
   Call AtcOut'retracts atc
   Call SetUserDRO (1200,NewTool)'Store new tool as actual tool value
SetCurrentTool( NewTool )
End Sub
Function ZatcPosition()'Move to Z tool position and wait until position reached
   code("G53")'Move in Absolute Machine coordinates
   code("G00 Z-1") 'Z value as to be checked for exact match with carrousel height
   While(IsMoving())
      Sleep(100)'temporisation entre while++
   Wend
End Function
Function AtcIn()'Put old tool back to carrousel
      ActivateSignal(OUTPUT4)'Move carrousel air cylinder to the tool change position adjust output# to match atc slide
      code("g04 p01")
End Function
Function Unclamp()'Spindle: Tool Unclamp
       ActivateSignal(OUTPUT6)'Release the tool, adjust output number for drawbar output
code("g04 p01")'pause
End Function
Function AtcDown()'lowers atc to rotate
   ActivateSignal(OUTPUT5)'solonoid to lower atc
   code("G04 p01")'pause
End Function
'Sequence to determine the least travel to move for TC, CW or CCW
Function LeastTravel()
    NTool = 8 ' Number of tools changer holds
   CWPos = GetSelectedTool() - GetCurrentTool() ' Assume a CW move
   If CWPos < 0 Then ' CWPos < 0 ==> rtp < atp
      CWPos = CWPos + NTools
   End If
   CCWPos = NTools - CWPos
   If CWPos < CCWPos Then
      Call CW()
   Else
      Call CCW()
   End If
End Function
Function CW()'Rotation CW
   Dim x As Integer
   Dim CTPos As Integer 'Carrousel Tool Position Relative to OldTool Position
   CTPos=0
   ActivateSignal(OUTPUT7)'Turns the AC Motor On
   Deactivatesignal(output8)'atc motor revirsing relay
   Sleep(50)
For x=0 To CWPos
           While IsActive(input1)'Wait for INPUT1 is off
Sleep(10)
   Wend
           While NOT IsActive(input1)'Wait for INPUT1 is on
Sleep(10)
   Wend
Sleep(10)
   Wend
Sleep(10)
   Wend
            x=x+1
        Next x
    CTPos=x
   DeactivateSignal(OUTPUT7)
End Function
Function CCW()'Rotation CCW
   Dim y As Integer
   CTPos=0
   Activatesignal(output8)'atc motor revirsing relay
    Sleep(50)
  For y=0 To CCWPos
Sleep(10)
   Wend
Sleep(10)
   Wend
Sleep(10)
   Wend
Sleep(10)
   Wend
            y=y+1
        Next y
   CTPos=y
End Function
Function AtcUp()'lifts atc
   DeActivateSignal(OUTPUT5)'relay for solonoid to lower/lift atc
End Function
Function Clamp()'power drawbar unactivated
   DeactivateSignal(OUTPUT6)'unactivating drawbar relay
End Function
Function AtcOut()'retracts atc
      deActivateSignal(OUTPUT4)'atc retract cylinder relay
      code("g04 p01")
End Function
« Reply #12 on: March 17, 2017, 09:34:34 PM »
Hello, i tried that and its much better. i will tinker with it a bit and try to see what the issues, it seems to work fine if i change 1 tool number at a time (ex. t7 to t8) if i go multiple (ex. t1 to t4) it acts up. it seems like it over shoots the sensor some times like the response time is to slow so instead of ending with input1 active it will over shoot and end in a non active state.
Thanks for all your help so far.
Offline TPS
  •  2,505 2,505
« Reply #13 on: March 19, 2017, 11:12:57 AM »
something new ?
« Reply #14 on: May 04, 2017, 07:38:15 PM »
hello, ended up replacing the motor with a stepper motor coding will be much simpler now, i have one issue i need to solve,
in my new macro i have an equation which works but i need to figure out how to get the answer then move the stepper accordingly
ex.
s = (newtool - 1)*45
code "g00 a(s)"
so if it was tool 5 the equation would be
s = (5-1)*45
code" g00 a180"
when i'm in vb editor and i hover over "S" it will show the answer (ex. 180) but in the code line its not reading "S" as a number
whats the proper way to do that?
Offline TPS
  •  2,505 2,505
« Reply #15 on: June 21, 2017, 08:42:28 AM »
code "g00 a" + CStr(s)
