Hello Guest it is October 30, 2026, 10:09:24 AM
Author Topic: Mach4/Lua script do's and Dont's  (Read 16756 times)
« on: March 13, 2017, 03:05:26 PM »
I am hoping someone can explain the do's and don't's of Mach4/Lua and  macro scripts and GUI's and how they interplay.
As I understand it there are two instances of Mach4 Lua code running simultaneously.  One for the GUI(screen load script) and one for running macros/gcode/movement?
I was told to create a module for code that is to be used by both the screen and macro scripts.  I have some code that I put in the mach4hobby\modules directory and named it rtMyModulse.lua. It contains 3 functions at this point.
My ScrrenLoadScript contains:  rt=require "rtMyModule" in the load modules section which successfully instantiates rt for use in the screen.
The first two functions work as expected from both the a screen button and a call to a macro (m9002.mcs example below).
The third function rtProbeX(dir) also works in a button script: rt.rtProbeX(1).
However, when I call m9000 from the mdi, or from a button using: mc.mcCntlMdiExecute(inst,"m9000"), it calls rtProbeX and executes the first part past the 'quick strike' and then fails.
Can a macro run several mcCntlExecuteGcodeWait?
Can a function in a module be called by a macro and execute several mcCntlExecuteGcodeWait?
Can you mcCntlSetLastError from a macro?
Can a function in a module be called by a macro and execute mcCntlSetLastError?
I've read that Lua does not have real threads but do the Gui and macro scripts not communicate/syncronize through callbacks or coroutine?
Are there any whitepapers on Mach4 structure and interplay?
rtMyModule.lua
Code: [Select]
ocal rtModule = {}
  local profile = mc.mcProfileGetName(inst)
  local path = mc.mcCntlGetMachDir(inst)
  function rtModule.rtMessage(msg)
    wx.wxMessageBox(msg)
  end
  function rtModule.rtAudio(fileName)
    local audio=wx.wxSound(path.."\\Sounds\\"..fileName..".wav",inst)
    audio:Play()
  end
  function rtModule.rtAudioCountDown(StartNum,EndNum)
    local i=StartNum
    while i>=EndNum do
      rtModule.rtAudio(""..i)
      wx.wxMilliSleep(900)
      i=i-1
    end
  end
 function rtModule.rtProbeX(Dir)
  local r1,r2,r3,retVal,rc
  --  local inst=mc.mcGetInstance()
  local xStart,rc
  xStart=mc.mcAxisGetPos(inst,0)-- Save starting X pos
  -- mc.mcCntlSetLastError(inst,"")
  mc.mcCntlGcodeExecuteWait(inst,"G31 X0 F4")  -- Quick strike
  r1,rc=mc.mcAxisGetProbePos(inst,0,false)
  mc.mcCntlGcodeExecuteWait(inst,'G01 X'..tostring(mc.mcAxisGetPos(inst,0)+0.030*Dir)..' F4') --Back off
  mc.mcCntlGcodeExecuteWait(inst,'G31 X0 F0.5')  -- First slow strike
  mc.mcCntlGcodeExecuteWait(inst,'G31 X0 F0.5') -- Second slow strike
  r2,rc=mc.mcAxisGetProbePos(inst,0,false)
  mc.mcCntlGcodeExecuteWait(inst,'G31 X0 F0.5') -- Third slow strike
  r3,rc=mc.mcAxisGetProbePos(inst,0,false)
  mc.mcCntlGcodeExecuteWait(inst,'G01 F8 X'..xStart)--return to starting position
  retVal=(r1+r2+r3)/3  -- average the strikes
  --  mc.mcCntlSetLastError(inst,string.format("%1.4f - %1.4f - %1.4f ",r1,r2,r3))
  return retVal
end
return rtModule
m9000.mcs
Code: [Select]
--m9000 lathe centering probe
function m9000(hVars)
    local xDis=1
    local zDis=.25
    local zStart
    local zEnd
    local xPos
    local xNeg
    local flag, rc
    local rt = require "rtMyModule"
    local inst = mc.mcGetInstance() -- Get the current instance
    local nilPoundVar = mc.mcCntlGetPoundVar(inst,0)
    local message = ""
    if hVars ~= nil then
      flag, rc = mc.mcCntlGetLocalVarFlag(inst, hVars, mc.SV_X)
      if (flag == 1) then
        xDis, rc = mc.mcCntlGetLocalVar(inst, hVars, mc.SV_X)
        if xDis==nil then
          xDis=1
        end
      end
      flag, rc = mc.mcCntlGetLocalVarFlag(inst, hVars, mc.SV_Z)
      if (flag == 1) then
        zDis, rc = mc.mcCntlGetLocalVar(inst, hVars, mc.SV_Z)
        if zdis==nil then
          zDis=0.25
        end
      end
    end
    mc.mcAxisSetPos(inst,0,0)
    zStart,rc=mc.mcAxisGetPos(inst,2)
    zEnd=zStart-zDis
    mc.mcCntlGcodeExecuteWait(inst,'G0 F1 X'..xDis..'\nG0 F1 Z'..zEnd)
    --mc.mcCntlSetLastError(inst, "Probing for Positive X" )
    xPos= rt.rtProbeX(1)
    mc.mcCntlGcodeExecuteWait(inst,'G0 Z'..zStart)
    mc.mcCntlGcodeExecuteWait(inst,'G0 X'..-xDis)
    mc.mcCntlGcodeExecuteWait(inst,'G0 Z'..tostring(zStart-zDis))
    --mc.mcCntlSetLastError(inst, "Probing for Negative X" )
    xNeg= rt.rtProbeX(-1)
    mc.mcCntlGcodeExecuteWait(inst,'g01 f8 X'..tostring(2*xPos-(xPos-xNeg)))
end
    m9000(0)
end
m9002.mcs
Code: [Select]
function m9002()  --testing load rtMyModule
 mc.mcCntlGcodeExecuteWait(inst,"g1F4 x1")
 if rt==nil then
    wx.wxMessageBox("rt==nil")
  else
    rt.rtMessage('Another Hello')
  end
end
if mc.mcInEditor()==1 then
  m9002()
end
Can anyone enlighten this old dog as to why this fails and what the rules and regulations are for scripting screen use and macro use?
RT
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Mach4/Lua script do's and Dont's
« Reply #1 on: March 13, 2017, 03:51:53 PM »
Did you add the load_modules.lua into the macros directory that brett posted?? to me it looks like your not loading the module. once loaded into the load_module.lua file all the macros only need call a function from the file.
DazTheGas
« Reply #2 on: March 13, 2017, 04:06:27 PM »
The best I understand it.......
mcCntlExecuteGcodeWait is to be called only from screen button scripts.
Nope, will have to use coroutines in modules
Yup
Think so, will have to test to be sure.
« Last Edit: March 13, 2017, 04:08:08 PM by Chaoticone »
« Reply #3 on: March 13, 2017, 04:10:04 PM »
Hi Daz,
Yes, the module does actually load, I am able to call the rtAudio and the rtCountDown through m calls so I know the module is loaded, and the call to rtProbeX actually issues the first g31 'Quick Strike' and backs off and then hangs.  No movement after that.  If I wait and press stop I would actually get a lasterror displayed, before I commented them out.
Just saw Chaoticone's response.  Not able to use GcodeExecuteWait.  I'll try gCodeExecute unless he tells me that's a no-no too.
RT
« Reply #4 on: March 13, 2017, 04:19:07 PM »
Yup, just tested it and it does work.
I think you will need to use MdiExecute. I still get confused on the 3 different executes myself but I think if called from anything other than a button, MdiExecute is the right one to use.
« Reply #5 on: March 13, 2017, 04:42:40 PM »
I don't believe that is going to work either.  mdiExecute will only execute lines of gCode/mCode and returns immediately before the code is fully executed.  If I want to get the result of a probe I can't do that until the strike has occurred.  It seems we are back to the old while isMoving() sleep for a while except we don't have that function anymore.
Does the mcCntlIsInCycle work for files only or mdi and macro calls to execute gcode?
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #6 on: March 13, 2017, 05:06:06 PM »
Ive not had any problems using mcCntlGcodeExecuteWait in macros to date, however you could consider instead of
Code: [Select]
    mc.mcCntlGcodeExecuteWait(inst,'G0 Z'..zStart )
use something like this
Code: [Select]
mc.mcCntlGcodeExecuteWait(inst,'G0 Z'..zStart..'\n G0 X'..-xDis..'\n G0 Z'..tostring(zStart-zDis))
I created a load_modules.mcs and placed it in my macro`s folder with the following
Code: [Select]
-- Load modules that you want to be able to use from Mcodes
package.path = path .."\\Modules\\?.lua;"
package.loaded.rtModule = nil
macros do not then need to require the file again just call the functions
Code: [Select]
 if rt  == nil then
  else
  end
end
and all runs fine, it could simply be hanging due to not loading the module but if I get time I will run the m9000 and see
DazTheGas
« Reply #7 on: March 13, 2017, 07:23:01 PM »
I think you will find that the only way to do what you want is by using a coroutine. Check the default Ref all home button, Ref all home function in the screen load script and coroutine resume in the plc script. Can also look at the TouchOff module.
If you put message boxes in between the following lines I think you will see that the message boxes pop up immediately if it is ran from a macro or module. They will not wait until motion stops.
« Reply #8 on: March 14, 2017, 10:20:53 AM »
Here is an example of using a coroutine. This is an update that will be making into the default screens at some point along with many other major changes I plan.
