Hello Guest it is April 26, 2024, 12:38:34 PM
Author Topic: +1mm -.99mm?  (Read 7085 times)
Re: +1mm -.99mm?
« Reply #10 on: March 29, 2017, 01:15:50 AM »
Hi all
After researching the G540 it seemed the obvious choice, I received it yesterday and started planning a small control box. The basis is the power supply fan will draw air into the box assisted by a small exhaust fan at the opposite end of the box, the positioning of the units and a ducting panel will force the air flow through and under the power supply then upward and through a heat sink I intend to add to the back of the G540 before being exhausted out of the box.
Then I saw this.     http://youtu.be/TuG_4q1UXnc    Now I'm wondering what your thoughts on this are as my electronics experience is very limited.
Thanks Mick.
