Hello
Guest
it is
March 29, 2024, 02:46:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
HiCON Motion Controller
(Moderator:
Vital System Support
"unable to ARM drive (code=355)"
Poll
when trying to enable in mach4 why do i get this error "unable to ARM drive (code=355)"?
Hicon
1 (100%)
mach4
0 (0%)
Total Members Voted:
1
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: "unable to ARM drive (code=355)" (Read 10385 times)
francocncprojects
26
Re: "unable to ARM drive (code=355)"
Reply #10 on:
May 24, 2017, 09:31:05 PM »
Hi. I get the errors when I use the screen I downloaded from Vital Systems website. When I use the generic screen that came with Mach4 install, the errors go away.
Logged
394
Reply #11 on:
May 24, 2017, 09:33:30 PM »
yes I saw this error. you are right it is in the screen. tomorrow should upload the fix.
Logged
francocncprojects
26
Reply #12 on:
May 24, 2017, 09:39:47 PM »
Cool. You guys are awesome. I'm happy to use the wx4_VSI when it becomes available but I'm curious - will there be problems if I use other screens? Are there special scripts on the wx_VSI?
I'm one of those people that likes to ask a lot of questions - in case you haven't noticed.
Thanks!
Logged
394
Reply #13 on:
May 24, 2017, 09:44:27 PM »
you can use other screens. All the config is in the porfile ini file. we renamed the screen so it does not overwrite any new screen from machSupport. We used to have some updates in the screeen scripts some months, but now the default screen is in pretty good shape.
we still like you, if you are our customer
-Rufi
Logged
enmanuelparache
2
Reply #14 on:
June 26, 2017, 01:47:35 PM »
How can I reactivate the "Arm Enabled" feature?
For some reason the HiCon I'm using lost it and now I'm getting the "unable to ARM drive (code=355)" message on Mach4.
Last Edit: June 26, 2017, 01:49:15 PM by enmanuelparache
Logged
394
Reply #15 on:
June 26, 2017, 05:37:24 PM »
you can email to support to get the activation key.
Logged
enmanuelparache
2
Reply #16 on:
June 27, 2017, 08:06:27 AM »
Thanks!
Logged
Boots
17
Reply #17 on:
May 13, 2019, 05:54:24 PM »
I am also having problems when I try to enable Mach4 it comes up with error 355. Unable to arm drives
I have:
7766, 7377 closed loop 4 drives
Logged
394
Reply #18 on:
May 13, 2019, 05:58:06 PM »
Looks like you are missing ARM enable activation.
please contact support@vitalsystem.com and provide serial number of the controller and the order ID.
thank you
Tech Support
Logged
Print
Pages:
1
2
Go Up
« previous
next »
