Hello Guest it is April 18, 2024, 02:17:07 AM
Author Topic: Pokeys57CNC, Mach4 and fusion probing - does it work?  (Read 2482 times)
« on: March 06, 2017, 01:51:40 PM »
Hey guys,
So simple question before I go and break a probe - has anyone tried the built in fusion probing stuff and does it work with the 57CNC and mach4?
Oh and as an aside bonus question: If anyone can answer this for me that'd be cool - I currently have an NC touch probe connected to the probe port... I use this for setting X/Y but as I don't have indexed tools I'm then a bit stuffed for Z. Is there anyway to also use a NO electric touch plate type setup to set Z-height of the actual tool without using the same port and having to reverse the switch logic each time?
Offline thosj
  •  532 532
Re: Pokeys57CNC, Mach4 and fusion probing - does it work?
« Reply #1 on: March 06, 2017, 02:01:07 PM »
Can't answer the first question, nor can I answer the second question to your satisfaction, but just to be smarmy, a PMDX-126 can do the multiple probe type thing and in hardware so you only need one pin for all that >:D
Tom
« Reply #2 on: March 06, 2017, 02:04:49 PM »
Pokeys does seem quite configurable so I'd be surprised if it wasn't possible some how. I'm just a bit dense when it comes to electronics and programming.
« Last Edit: March 06, 2017, 02:08:37 PM by Zeeflyboy »
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: May 19, 2017, 01:20:24 AM »
PoKeys57CNC does indeed support probing. It may be unclear to me what you mean by fusion probing, so can't answer it.
Regarding the polarity of the probe input - the plugin does not expect this to change during runtime. The best way to solve it to use the NO switch and the touch pad in parallel.
