Hello Guest it is April 18, 2024, 07:09:13 PM
Author Topic: Single block mode  (Read 5121 times)
Re: Single block mode
« Reply #10 on: March 09, 2017, 06:11:32 PM »
Thanks Tom for helping.  With the previous info it was very easy.
It was my first edit of the Mac4 screens.  I have modified the Mach3 before but I am just getting Mach$ up and running now.
I also changed the DRO decimals since I am using metric and I do not need 0.0000.
Thanks again,
Bertho
Offline thosj
  •  532 532
« Reply #11 on: March 12, 2017, 09:54:46 AM »
I forgot to mention, Bertho, and you may know to do this, but save our edited screen set to some other name so if you upgrade Mach4 it doesn't get overwritten.
Tom
« Reply #12 on: November 18, 2022, 06:50:20 PM »
Single block mode works fine in mach4 however the state of the cycle start button is not correct and is disabled in single block mode. open up the screen editor and select the cycle start button, in the properties for the button you will find enabled states and in there you need to put a check in the File Single Block and save and exit the editor. You should now find the button enabled during a single block mode state allowing the function to work correctly.
DazTheGas
I followed this procedure, and to my surprise the “file single block” was already checked.
The problem I’m having is, I cannot find the single block button on the screen.
Any idea of what I’m doing wrong?
Chuck
« Reply #13 on: November 19, 2022, 12:38:22 PM »
I found it, it’s under “run ops”
