Hello Guest it is March 28, 2024, 06:01:02 PM
Author Topic: New screenset for Mach3 Mill - Ease-eMill  (Read 12892 times)
Offline DaBase
  •  36 36
  • Metalhead
« on: February 23, 2017, 02:14:33 PM »
We are glad to announce you the new Ease-eMill for Mach3 Mill Screenset!
This thing turns your Mach3 Mill into completely user friendly product!
Features:
16:9 ratio adjusted Screenset! Enough with the old-fashioned 1024x768!
Large toolpath window
Files included for CSMIO-IP/S by CS-Lab
Distance To Go for visual reference to avoid any crash
Current Work Offset (G54, G55, G56 etc.) appearance on display
Feed override slider
Spindle override slider
Spindle load monitoring in two ways:
* By reading from VFD analog output (0-10V)
* By comparing True and Set RPM
Optional Hydraulics/Air compressor On/Off switch
Easy to use separate Offsets window for setting Tool and Work offsets
Separate window for all coordinate systems (Machine, Axis, Work)
M01 Break (Optional Stop) button with LED
Included Macro for rotational or linear Automatic Tool Change with logics to go shortest distance, easy to configure for 4-bit encoder or using switches
User friendly safety logics preventing against crash
* Protection against wrong tool (for example, Tool 0 instead of 1) by warning user with pop-up window
* Preventing Cycle Start before homing all axis after Reset
* Waiting for Spindle while it spins up to commanded RPM, then allows program to continue
Auto Tool setting macro
Auto Part setting macro
Brain included:
Brain for controling Hydraulics (settable Output pin) button on screenset
Brain for external Pause and Stop buttons
Brain for Spindle Load meter, if no Analog Input from VFD (comparing True RPM and Commanded RPM)
Brain for Lubrication alarm (no oil)
Screenset is available in Metric and Imperial versions.
Install instructions are on YouTube: https://www.youtube.com/watch?v=JV-aRS4-4ew
Price for the Screenset is 25 Eur via PayPal, please write me PM about buying it.
We <3 to Code();
Re: New screenset for Mach3 Mill - Ease-eMill
« Reply #1 on: March 29, 2017, 06:54:06 AM »
Has anyone purchased and used this yet? any reviews
« Reply #2 on: May 03, 2017, 10:47:45 AM »
Good job.
Jog lacks Cont and Step.
In the future you are going to Conversational as in turn
« Reply #3 on: June 12, 2017, 05:02:40 AM »
want to buy this screen set.
« Reply #4 on: June 12, 2017, 11:25:14 PM »
want to buy this screen set, anyone knows how?
i have pm the guy, but got no update so far.
Offline DaBase
  •  36 36
  • Metalhead
« Reply #5 on: July 18, 2017, 12:16:28 PM »
I'm back  ;D
We <3 to Code();
« Reply #6 on: July 18, 2017, 03:03:55 PM »
You've got some improvement.
« Reply #7 on: September 27, 2018, 12:21:42 PM »
Hi DaBase
Paid three days ago. Still waiting for my screen set.
Deon Gerber
If A is a success in life, then A equals X plus Y plus Z.
                               Work is X: Y is play and Z is keeping
                                                             your mouth shut.
« Reply #8 on: September 29, 2018, 05:47:42 AM »
And still waiting! ???
                                                             your mouth shut.
« Reply #9 on: October 01, 2018, 01:46:03 AM »
And.....wait for it........still waiting.
Got a message to check my mail but still waiting.  ???
                                                             your mouth shut.
