Hello Guest it is April 19, 2024, 11:13:14 PM
Author Topic: DEMO MODE - ISSUE WITH COUNTS PER UNIT  (Read 1325 times)
« on: February 20, 2017, 10:47:24 AM »
Hi There,
I am currently testing my motors with Resolution of 500 Pulse/Rev for both X-Axis and Y-Axis. Y-Axis have a slave motor tied to it. I am using the demo version.
Its direct rack and pinion drive with spur gear travel 100mm in axis per revolution. The Counts per unit keyed in for both axis is 10 for all 3 motors.
My issue is when i try to run G0 X100 in MDI, the X-Axis does not turn full one revolution. It only runs half revolution.
The Y-Axis is spot on.
Please advice. Thanks.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: DEMO MODE - ISSUE WITH COUNTS PER UNIT
« Reply #1 on: February 20, 2017, 10:58:46 AM »
Not sure if your running lathe but this from steve might help.
http://www.machsupport.com/forum/index.php/topic,34274.msg237068.html#msg237068
DazTheGas
« Reply #2 on: February 20, 2017, 11:09:31 AM »
Thanks for the pointer. Issue solved. Cheers.
