Hello
Guest
it is
April 24, 2024, 04:18:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 X Axis Moving The Wrong Direction
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 X Axis Moving The Wrong Direction (Read 8507 times)
addicted2dunes
2
on:
February 19, 2017, 02:31:49 AM »
I'm sure you guys have answered this a million times but I came up empty on how to solve this issue. My X axis is moving the wrong direction (mirrored). I tried going in Config-Homing/Limits and checked the reverse box, but it didn't change anything, even after a restart. Am I missing something? Is there a way to reverse this? Or do I need to reverse the wiring or something? Thank you for your time.
Logged
Tweakie.CNC
9,199
Super Kitty
Re: Mach3 X Axis Moving The Wrong Direction
Reply #1 on:
February 19, 2017, 02:39:38 AM »
Config. / Ports and Pins / Motor Outputs - Change the Dir Low Active state for the axis in question then Apply.
Logged
addicted2dunes
2
Reply #2 on:
February 19, 2017, 11:43:29 AM »
Oh my god, thank you, that solved it, I was racking my brain on this and couldn't find the answer. Again, thank you so much.
Logged
Winston harmitt
5
Reply #3 on:
June 15, 2018, 05:19:32 PM »
This does not help me because my display reads negative from home in X and when I get it to read positive it will not bounce of the microswitch it tries to keep going When I get it to bounce off microswitch it reads negative from microswitch changing the left and right arrow as well
Logged
Print
Pages:
1
Go Up
« previous
next »
