Hello Guest it is April 26, 2024, 06:57:48 AM
Author Topic: Jogging from Plugin  (Read 2719 times)
Jogging from Plugin
« on: February 13, 2017, 03:40:41 AM »
All,
both using Mach3 and Mach4. In Mach4 there is a demo where one can use the mouse trakcball to jog an axis. I was looking forward to write a plugin which does the same for Mach3, just to get more familiarized with writing plug-ins. Based on the example of the Joystick which is provided by the SDK (using Mach3 Plugin Wizard), I'm trying to perform a jog by using the following code:
// Setting the parameters for the jog
   Engine->Axis[ XJoyAxis].JoggDir = 0;
   Engine->Axis[ XJoyAxis].MaxVelocity =  (int) (MaxX );
   Engine->Axis[ XJoyAxis].Acceleration = AccSecX;
   Engine->Axis[ XJoyAxis].MasterVelocity = VelMaxX;
//Starting the jog
   Engine->Axis[ XJoyAxis].Dec = false;
   Engine->Axis[ XJoyAxis].Jogging = true;
I also tried to narrow down the mistake by supplying hard-coded valuies for velocity and accelaration, but no avail:
   Engine->Axis[ XJoyAxis].MaxVelocity =  10000;
   Engine->Axis[ XJoyAxis].Acceleration = 1000;
   Engine->Axis[ XJoyAxis].MasterVelocity = 100000;
//Starting the jog
What am I missing in this setup. Should there be an option i Engine which should be set (the term Jogging is used on multiple objects in the Mach includes)...
Hope somebody can put me on the right track here.
