Hello Guest it is April 25, 2024, 10:58:06 PM
Author Topic: Position Loss Issue  (Read 1401 times)
Position Loss Issue
« on: February 10, 2017, 04:08:24 AM »
hi all,
What i've done so far to drive my metric Sherline mill is to install UC100 + Mach3 on my desktop and then used the XML file for sherline metric off the ftp.machsupport.com/XMLs but when I run test code to cut a simple profile such as a square I get very bad loss of position every cycle:
Anybody able to help me troubleshoot this issue? I'm helpless, and have disassembled the mill a number of times to check backlash and what not...
Regards
  •  9,199 9,199
Re: Position Loss Issue
« Reply #1 on: February 10, 2017, 05:23:11 AM »
Try reducing your Velocity and Acceleration in Motor Tuning by 50 % for your X and Y axes (saving the changes for each axis).
Does your machine still loose position ?
