Hello Guest it is April 18, 2024, 09:05:04 PM
Author Topic: Variables and Parameters list  (Read 8050 times)
Re: Variables and Parameters list
« Reply #10 on: February 06, 2017, 08:56:30 AM »
After a few days of probing and testing the algorithm, finally I can say them work.
By now this ones wich I share here are working.
For each machine you have to set some parameters in the file O9724.txt where you have to put the feed rate, the tolerance of your measures and other thing commented there.
If you have any doubt about what are the place where the values go to be stored check the excel table attached where it says where it gonna be. There's a trick, where the Haas variable number is commented in the programs you will se theres is a diference of 50 positions exactly. That was a way to make the program fit in the place where I know that I can make changes.
Anyway, hope you can use them and when I finish another cycle I will share with you.
Franco
