Hello Guest it is April 19, 2024, 08:09:40 PM
Author Topic: Question on Toolpath?  (Read 3156 times)
Offline Mauri
  •  328 328
« on: January 22, 2017, 04:35:16 PM »
Is there a way to only display the Gcode Toolpath as it is being processed (cutting) and not the full Toolpath of the loaded Gcode?
Mauri.
Offline smurph
  •  1,546 1,546
Re: Question on Toolpath?
« Reply #1 on: January 22, 2017, 06:24:15 PM »
Unfortunately, not at this time.  :(
Steve
« Reply #2 on: January 27, 2017, 08:25:55 PM »
Hi Mauri,
could you not achieve something similar by making the Gcode path the same colour as the background?
The cut path would stand out only.
« Reply #3 on: January 27, 2017, 08:33:19 PM »
Hi Mauri,
I just tried it out, I made both the top background and bottom background colour the same likewise the rapids, the linear gcodes and the
arc gcodes. The toolpath loads but you don't see it until the job runs.
Offline Mauri
  •  328 328
« Reply #4 on: January 28, 2017, 02:15:32 PM »
Craig,
My question on this is, does it have any affect on the GPU usage?
My requirement would be not to display the loaded G-Code, hence no GPU usage on this through the cycle process, but display the actual cutting of the part of the G-code.
I am not sure changing colors would make any difference.
If I knew how to stop (turn off) this first G-code Toolpath display, then this would achieve the low GPU usage I am after.
Mauri.
« Reply #5 on: January 28, 2017, 04:12:26 PM »
Hi Mauri,
no the GPU usage is the same, its just that you cant see it.
Isn't there a control on the Mach/Toolpath page  'VBO', its my understanding, possibly mistakenly, that turns the toolpath display off altogether.
That would reduce GPU usage for sure!
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #6 on: January 28, 2017, 04:21:39 PM »
from this post by smurf
http://www.machsupport.com/forum/index.php/topic,34027.msg235880.html#msg235880
There are two options on how the tool path is run.  Vertex Buffer Objects (aka VBOs, and requires OpenGL version >= 1.5) and the old Mach 3 way.  We test for the v1.5 and if the driver supports it, we use VBOs.  Typically, using VBOs puts more of the work on the GPU and less on the CPU.  But usually, it also lends to smoother video as most graphics cards have faster memory that the RAM that the CPU uses.
Offline Mauri
  •  328 328
« Reply #7 on: January 28, 2017, 05:06:20 PM »
Daz,
I fully understand that.
Mach4 is written to cater for old video cards that operate as low as V1.5 OpenGL and use single thread CPU processing.
This thread questioning whether we can eventually get an option not to display the initial full G-code at all, but just the G-code Toolpath that is being processed.
Steve answered that by saying not yet.
Mauri.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #8 on: January 28, 2017, 05:27:59 PM »
Sori Mauri that was for craig in regards to
DazTheGas
