Hello I posted this question in another section but no luck. I want to be able to calibrate two axis at once in mach3 using the auto-calibration feature but it only allows one axis at a time. I need it to move the Y axis and its slave axis at the same time (B). Below is the file that runs the script but I am not sure what to tweak. So I am hoping someone can help me.
Sub Main()
Begin Dialog GroupSample 31,32,120,96,"Axis Selection"
OKButton 38,75,40,14
GroupBox 12,8,96,62,"Pick Axis to Calibrate",.GroupBox1
OptionGroup .OptionGroup1
OptionButton 20,24,40,8,"X Axis",.OptionButton1
OptionButton 20,40,40,8,"Y Axis",.OptionButton2
OptionButton 20,56,40,8,"Z Axis",.OptionButton3
OptionButton 67,24,40,8,"A Axis",.OptionButton4
OptionButton 67,40,40,8,"B Axis",.OptionButton5
OptionButton 67,56,40,8,"C Axis",.OptionButton6
End Dialog
Dim Dlg1 As GroupSample
Button = Dialog (Dlg1)
If Button = 0 Then
Exit Sub
End If
AxisNum = Dlg1.OptionGroup1
Select Case AxisNum
Case 0 'HSS
Axis = "StepsPerAxisX"
Axis_Letter = "X"
Case 1 'HSStin
Axis = "StepsPerAxisY"
Axis_Letter =" Y"
Case 2 'Carbide
Axis = "StepsPerAxisZ"
Axis_Letter = "Z"
Case 3 'Carbide
Axis = "StepsPerAxisA"
Axis_Letter = "A"
Case 4 'Carbide
Axis = "StepsPerAxisB"
Axis_Letter = "B"
Case 5 'Carbide
Axis = "StepsPerAxisC"
Axis_Letter = "C"
End Select
Com_Move = Question ("How far would you like to Move the " & Axis_Letter & " Axis?")
If COM_Move = 0 Then
MsgBox "Can't have a Move of Zero, Axis Calc aborted."
Exit Sub
End If
Code "G0 G91 " & Axis_Letter & Com_Move
While Ismoving()
Wend
Code("G90")
Code "G4 P0.5"
Act_Move = Question("How far did the " & Axis_Letter & " Axis move? (Measured Value)")
If Act_Move = 0 Then
Exit Sub
End If
Old_PPR = GetParam(Axis)
New_PPR = Abs((Com_Move/Act_Move) * Old_PPR)
Response = MsgBox ( Axis_Letter & " Axis Will be Set to " & New_PPR & " Steps per Unit. Would you like to Accept it??", 4 , "Set Steps Per Unit")
If Response = 6 Then ' User chose Yes.
Call SetParam(Axis, New_PPR)
MsgBox (Axis_Letter & " Axis Has Been Set")
Else ' User chose No.
MsgBox (Axis_Letter & " Axis Has NOT Been Set")
End If
End Sub
Main
