Hello Guest it is March 29, 2024, 10:08:49 AM
Author Topic: Machdrives Tuna™ V2.06 for Windows now available. FREE!  (Read 3212 times)
« on: January 17, 2017, 10:15:09 PM »
The latest tuning software for Machdrives Dual Encoder Servo Drives is now available for free download.
Take a look. https://machdrives.com/tuna.aspx
    Compatible with Windows XP, 7, 8.x and 10. Supports older XP machines with USB 1.1 and .Net 2.0 framework.
    Displays metric or imperial distance and temperatures in Celcius or Farenheit.
    Supports multiple instances so several drives can be connected simultaneously.
    Real time eight channel scope with pan and zoom makes waveform analysis easy.
    Real time digital readouts on command, motor and load position and error.
    Real time statistical position error analysis. Can be used to optimize tuning or monitor machining operations.
    Easy parameter configuration. No need to stop drive and save changes. Key values directly or use plus and minus keys for live "nudge" of tuning values.
    In-built waveform generator for enhanced tuning.
