Hello Guest it is April 26, 2024, 04:07:03 PM
Author Topic: Main Screen Disapearance!  (Read 4029 times)
« on: January 15, 2017, 02:57:18 PM »
Suddenly, the main window in Mach Screen disappeared?!? Only the properties window shows…I rebooted, uninstalled, reinstalled ver 64 (was using ver 66)…still whenever I start Mach Screen the main window loads for a split second, then disappears, leaving behind the properties window…
Even looked for a registry setting, cannot figure this one out...
Any ideas?
Thank You
Leslie
Re: Main Screen Disapearance!
« Reply #1 on: January 15, 2017, 04:22:43 PM »
Hi Lesli,
To fix that problem please terminate MachScreen, press the „Shift“ key und hold it pressed down, start MachScreen while keeping the “Shift”  key pressed. That puts all MachScreen settings to default.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: January 15, 2017, 06:24:52 PM »
Thanks...will try it out tomorrow...watching football and eating wings right now!   ;D
