Hello Guest it is April 26, 2024, 11:13:49 AM
Author Topic: 4 Axis  (Read 1375 times)
Offline Mauri
  •  328 328
4 Axis
« on: January 14, 2017, 10:30:05 PM »
Below are what you see in Mach3 and madCAM Simulation, but not on Mach4 it appear in this example that only the XYZ have generated the image and not the A axis.
When doing just a circle it is also just a flat line.
If you offset the circle and then make the G-code on the Circle it will then make a circle, however if you do the to a full 3D like this Ball example it generates the G-Code incorrectly.
I will post the extra sample in the next post.
Mauri.
Offline Mauri
  •  328 328
Re: 4 Axis
« Reply #1 on: January 14, 2017, 10:38:25 PM »
This is the Offset G-code by 50% of the diameter.
The offset for axis was done on Rhino5/madCAM5 and NOT in Mach4, just the G-Code was used as it was produced in madCAM.
It shows an odd shape of the ball.
Mauri.
