Hello Guest it is April 18, 2024, 07:39:37 AM
Author Topic: Mach 3 transfer to another computer  (Read 2771 times)
« on: January 12, 2017, 10:24:10 AM »
How can I transfer my settings from one computer to another with out losing what I have done so far? I want to be able to transfer everything and start mach 3 and it is ready to run.
Thanks Nathan
Offline Davek0974
  •  2,606 2,606
Re: Mach 3 transfer to another computer
« Reply #1 on: January 12, 2017, 10:34:57 AM »
You need to get a copy of your Mach 3 folder onto a USB stick etc first.
Then set the new machine up, install Mach3, do the port test if using PP, install any custom drivers for controllers, joysticks and so on.
Now i just copy the Mach3 folder form USB and place it over the top of the new install, this will copy your settings, macros etc.
Create a new desktop shortcut if needed and should be good to go.
If using Ethernet smoothstepper controller or UC100/300 etc then these will need installing before copying over your old data.
This is on XP systems, i'm not sure if the newer Win7 setups are so easy.
« Reply #2 on: January 12, 2017, 11:46:59 AM »
Thank you!! Yes this will be on a Windows 7 system. This is quit yes to do then.
Nathan
