Hello Guest it is April 25, 2024, 07:42:06 AM
Author Topic: Constant Velocity settings worked out ... I think  (Read 11958 times)
Re: Constant Velocity settings worked out ... I think
« Reply #10 on: October 08, 2018, 07:10:14 AM »
Have had trouble for a while with vibration in certain tool paths.  Tried everything from lowering acceleration to setting CV angle to 90 degrees, upped lookahead line etc.  Everything tried so far seemed had limited success.  Tried this and so far there is a large improvement on vibration and also an increase on speed.  Same toolpath was reduced from 53 to 42 seconds.  Also tried some integrate work with 1/32 inch flute and was really impressed with the accuracy.
Many thanks for the suggestion Ithall.
